Preventing expensive peak currents while charging your forklift truck fleet
Selectiva battery chargers are actively preventing peak currents
At the end of a shift, all forklift trucks are driven back to their charging stations and their batteries are charged at the same time. This leads to increased energy consumption - especially at the start of the charging process - which can result in expensive peak currents. Should this occur on a regular basis, consumption will exceed the annual quota agreed with the energy supplier. Expensive supplementary payments due to the additional consumption and supply costs will surely follow. Many companies respond by disconnecting production machines or even entire warehouses and production areas from the grid and shutting them down when peak currents occur. Disruptions to the company's entire operations can thus be traced to the simultaneous peak current consumption of the battery charging systems.
How to prevent peak currents with the Calendar-Function
Delayed charging start
Enables users to set the time at which the charging process begins
Fully charged by a given time
Slow rise in energy consumption - the time until the battery has to be fully charged is given
The “delayed charging start” feature enables users to set the time at which the charging process begins, allowing individual charging processes (and thus the energy consumption) to be spread out over time so that peak currents do not occur. The start of the charging process can also be controlled using the calendar function on the battery charging systems. The user can set the desired charging start time on the device, irrespective of when the battery is connected.
Operators of large forklift truck fleets are able to start the charging process in individual departments or charging stations at different times, for example every 15 minutes. By avoiding the simultaneous peak current consumption of the battery charging systems in this way, energy costs are reduced.
With the function "fully charged by a given time" the time at which the batteries have to be fully charged is set. This enables a gentle and slow start of the charging process. The time available for charging of the batteries is used in the most efficient way. Elongated charging process limits the heating, this way the charging process is gentle to the battery. This has two major benefits: energy savings and extension of the battery life.
