WeldCube
Documentation and Analysis All welding data at a glance
Document welding data reliably
Transparency and safety, but also productivity and time-saving: the requirements are high in welding production. The recording, documentation and analysis of welding data is therefore becoming increasingly important. This is because direct feedback from production helps to optimize processes, monitor system statuses and identify errors. The result: reliable, high-quality production.
The WeldCube analysis system offers the right solution for all requirements—from small businesses to large companies with a wide range of networked welding systems. This means that you get optimum support with your data documentation.
Advantages of data documentation
Time costs
Save time and money
  • Automatic recording: No handwritten notes required
  • Assessments at the touch of a button
  • Early error detection
  • Central management of jobs
Tick
Increased safety in production
  • Traceability at component and seam level
  • Continuous documentation
  • Risks are minimized
Chart
Increase productivity
  • Identify potential optimizations
  • Each weld seam under observation
  • The system status at a glance
Read more about the topic of data management here
Quality assurance and transparency
Wherever welding is carried out, manufacturers and users expect perfect and demonstrable quality. Ultimately, stable and flawless weld seams are crucial to ensuring that safety and functionality criteria are met. A continuous quality assurance process is therefore essential in the majority of companies. Safe and documented welding
EN1090 certificate
EU Standard EN 1090 requires welding data documentation
Since 2014, load-bearing steel or aluminum structures may only still be sold if they comply with the EN 1090 series of standards.
The EU standard requires full documentation of the weld seams so that they can be consistently traced.
To Dekassian reference
Monitor
Documentation at component level
The component-level documentation enables weld seams to be assigned to a component and a welding system. This makes it possible to produce components with consistent traceability.
Statistics
Preparing statistics
Statistics functions allow you to quickly and easily create and visualize useful analyses. This has many advantages for you, including helping you to optimize production processes.
Our example shows the highest error rate per day and welding system, analyzed using WeldCube Premium. Using these data, individual stages of production can be examined in further detail and improved as necessary.
WeldCube: different variants for any requirements
Documentation
Centralized data documentation
  • All data are stored in a central database
  • Data from all networked systems are displayed together
Documentation
Decentralized data documentation
  • Data are stored on the power source itself
  • Always one power source at a time: view or process data for each individual power source
WeldCube
Light
WeldCube Light is available in SmartManager in every TPS/i – at no additional cost. Averages for each weld seam are recorded directly in the welding system, visualized on a web basis for each TPS/i and provided as a PDF export.
Find out more about WeldCube Light
WeldCube
Basic
For users who need actual values with a scanning rate of up to 100 ms, limit monitoring or editing functions for set values alongside the average values, WeldCube Basic is the ideal solution. Here, the data is also recorded directly in the welding system and visualized on a web basis. Both a PDF and a CSV export are available as part of this process.
Find out more about WeldCube Basic
WeldCube
Premium
WeldCube Premium saves the welding data of networked Fronius systems in a database. In addition to the TPS/i, you can also use other digital welding systems as well as DeltaSpot with WeldCube Premium. The central storage allows for comprehensive and component-oriented documentation, assessment and analysis of the data. Table-based and graphical assessments are available at the touch of a button.
Find out more about WeldCube Premium
Automotive
Online demo of WeldCube Premium
Take the opportunity to gather your own initial impressions of the functions and usability of WeldCube Premium.
Using the guest login you can explore the world of WeldCube Premium straight away.
Login: guest
Password: guest
Click here for the Online-Demo
Laptop
Let’s get connected.
