A Fronius inverter with a Fronius Smart Meter at the feed-in point is required. The following Fronius inverters are compatible with the Wattpilot: GEN24, Verto, SnapINverter from Datamanager 2.0, as well as IG, IG Plus, IG TL and CL series in combination with a Datamanager 2.0. The combination with a Fronius Ohmpilot and a Fronius compatible DC-coupled battery is also possible.
The Wattpilot can also be operated with a third-party inverter in combination with a Smart Meter IP or a Datamanager Box 2.0 and Fronius Smart Meter at the feed-in point. However, no other self-consumption regulations (battery, Power2Heat, etc.) may be implemented in parallel, and household consumers are not taken into account in the display in the Solar.wattpilot app.
“Vehicle charges from” – this setting means that the Wattpilot may only use the entire PV surplus once the storage has reached this value. However, the Wattpilot can start charging before this value is reached, e.g. if the PV battery cannot be charged with a higher power and there is an additional PV surplus. Once “PV battery discharges” is activated, the PV battery will discharge to the value “Discharges to”.
Once the SOC level of the PV battery is higher than the value “Discharges to”, the Wattpilot may discharge the PV battery to the set limit. If the “Restrict time” function is also activated, the storage will only be discharged within the specified period.
Currently, there is no standard for smart charging. Therefore, certain car models may experience limitations in cost-optimized charging. Fronius is working to configure the optimal charging behavior for each vehicle.
The following car models are affected:
Since vehicle manufacturers continuously offer new software updates, limitations may have been resolved. You can find the selection of the car model in the Solar.wattpilot app under Settings - Cost Optimization - Car.
All settings can also be made locally by connecting to the Wattpilot's hotspot. This is permanently open and secured with a password. The following functions are not possible without a network connection:
Yes, prioritization is possible. If the same priority is set, the following prioritization applies:
If the same charging mode is used, the power is evenly distributed.
The Wattpilot Flex is equipped with ISO15118 communication hardware, which is a basic requirement for bidirectional charging. However, further requirements are necessary for bidirectional charging:
In short, while the Wattpilot Flex is equipped with ISO15118 hardware, it does not yet support bidirectional applications.
Tip: Pay close attention to wallboxes from other manufacturers, as ISO15118 hardware is often mistakenly equated with bidirectional charging!
All information about the charged electricity amounts is displayed in the Solar.wattpilot app and can be downloaded as a CSV file.
The Wattpilot Flex shows total energy, energy of the current charging session, and current charging power on the dot-matrix display.
You can add your Wattpilot to your PV system in Solar.web under the "Settings" – "Components" tab. You will need the serial number and the V-code (on the nameplate on the back of the device).
If you have not yet created a PV system in Solar.web, register at www.solarweb.com and add your Wattpilot and the coupled inverter when creating the PV system. When adding the Wattpilot to Solar.web, we recommend that the Wattpilot currently has an internet connection and is coupled with the inverter. It is also possible to add an offline Wattpilot to Solar.web, but Wattpilot data will only be displayed once the Wattpilot is online and coupled.
To ensure Wattpilot data is displayed in Solar.web, please make sure of the following:
For periods when the Wattpilot has no internet connection (e.g., due to weak Wi-Fi), no live and historical data will be displayed in Solar.web. The data will not be restored when the Wattpilot reconnects to the internet.
Furthermore, Wattpilot data will only be displayed if the Wattpilot is paired with an inverter that is in the same PV system in Solar.web. For example, no data will be displayed in Solar.web for periods when the Wattpilot Go is used on the go.
